JK Gears in a Standard D44 Housing
1 reply to this topic
#1 Build it
Build it
  • Vendor
  • 398 posts
  • LocationNaches
Posted 28 June 2013 - 10:27 AM
We're now supplying kits that allow you to install JK D44 gears (3.73 and lower) into a standard D44 Housing! The JK Version of the Dana 44 ring gear is  thicker than previous, standard D44 versions making it stronger than normal. Since the JK ring gear is thicker than standard, you'll need to move it away from the pinion by using a 3.73 and higher (numerically lower) carrier.
EXCLUDING carrier bearings, these kits come with everything you need, INCLUDING ring and pinion for only $400!
If you're adding gears and a locker to your Dana 44 anyways, this kit is a no brainer!
Edited by Build it, 28 June 2013 - 10:35 AM.
#2 ChevyJoe
ChevyJoe
  • 1,448 posts
Posted 28 June 2013 - 01:35 PM
Matt (coffeetruckequipment) is stoked to be running this kit from you guys!
