Dana 44 Help
9 replies to this topic
#1 Simple'72CJ
Simple'72CJ
  • 153 posts
  • LocationEllensburg, Wa
Posted 06 August 2016 - 09:43 AM
So my inner wheel bearing let go and ruined my spindle and locking hub.  Trying to get everything back together by next weekend and need to order a new spindle, but being I didn't build the front I'm trying to figure out which spindle to order.  The stub shaft is a a 30 spline and leaning towards a late 70's full size bronco spindle? Just needing some reassurance before ordering.
#2 Simple'72CJ
Simple'72CJ
  • 153 posts
Posted 06 August 2016 - 10:33 AM
All dimensions were pulled using a steel rule so very approximate
#3 Simple'72CJ
Simple'72CJ
  • 153 posts
Posted 06 August 2016 - 10:55 AM
Did more research and sounds like its either a Warn dana 30 30 spline outer specialty spindle or you can take a standard dana 30 and bore it to fit a 30 spline stub?
#4 Jay W
Jay W
  • 1,529 posts
Posted 06 August 2016 - 11:04 AM
What are the diameters on the spindle? Is the 30 spline shaft 1.5" od?
#5 Simple'72CJ
Simple'72CJ
  • 153 posts
Posted 06 August 2016 - 11:21 AM
OD of shaft is 1 1/4"
The smallest OD on the spindle is about 1 5/8"
Edited by Simple'72CJ, 06 August 2016 - 11:30 AM.
#6 Simple'72CJ
Simple'72CJ
  • 153 posts
Posted 06 August 2016 - 11:29 AM
Smallest OD - 1 39/64 -- 1.6094"
Middle OD - 1 23/32 -- 1.7188"
Large OD - 1 49/64 -- 1.7656"
Don't have a pair of calipers
#7 Jay W
Jay W
  • 1,529 posts
Posted 06 August 2016 - 11:35 AM
Probably 1 5/16, standard 30 spline od
#8 Simple'72CJ
Simple'72CJ
  • 153 posts
Posted 06 August 2016 - 11:39 AM
Correct, just changed my measuring method
#9 Jay W
Jay W
  • 1,529 posts
Posted 06 August 2016 - 12:00 PM
I could bore spindles for you if you don't have access to a machine shop before next weekend.
#10 Drunk Prom Date
Drunk Prom Date
  • 657 posts
  • LocationYakima, wa
Posted 28 October 2016 - 04:22 PM
I have a diff for sale.... 😬
Sent from my iPhone using Tapatalk
