Master cylinder bore size
10 replies to this topic
#1 Landabuser
Landabuser
  • 247 posts
  • LocationMaple Valley WA
Posted 13 January 2017 - 09:43 AM
I'm going to be switching to 4 wheel disk brakes using Chevy calipers. What non power assist  master cylinder do any of you run with this set up?
#2 Jenks
Jenks
  • 831 posts
  • LocationEllensburg
Posted 13 January 2017 - 11:03 AM
I used one off an early 70's chevy 1 ton with manual brakes on my old CJ7 with 4 wheel discs.  worked pretty well.
#3 Jay W
Jay W
  • 1,529 posts
Posted 13 January 2017 - 11:14 AM
60's corvette
#4 homeboy
homeboy
    Daddy D
  • 629 posts
  • LocationBC, Canada
Posted 13 January 2017 - 02:59 PM
What size calipers.
#5 SHREK
SHREK
  • 1,138 posts
  • LocationChehalis
Posted 13 January 2017 - 03:08 PM
I would do power assist if I could do it over again.
#6 Landabuser
Landabuser
  • 247 posts
Posted 13 January 2017 - 07:58 PM
Caliper pistons are 2 15/16 diameter.
Trentfab said if I run a 15 inch pedal, (I do have room) I won't need power assist.
#7 SHREK
SHREK
  • 1,138 posts
  • LocationChehalis
Posted 14 January 2017 - 07:26 AM
With 12" rotors and 40" +- tires I think the assist is worth the effort. I'm running what you explained, they work but I wouldn't call them good.
#8 Atkins
Atkins
  • 165 posts
  • LocationGleed
Posted 14 January 2017 - 08:56 AM
Power assist if you have room!  Manuel brakes and big tires are not the safest set up.
#9 POR
POR
  • 584 posts
  • LocationYour moms
Posted 14 January 2017 - 10:10 AM
Just get the dual 3/4" cnc masters, you'll be fine
#10 POR
POR
  • 584 posts
  • LocationYour moms
Posted 14 January 2017 - 10:12 AM
Get the cnc gas pedal too, that will make life a lot easier as well
#11 POR
POR
  • 584 posts
  • LocationYour moms
Posted 14 January 2017 - 10:13 AM
One more question.. did you throw the manual away yet?? 😂😂
